RCU Forums - View Single Post - Help with finding a pre-painted body
Old 06-21-2016 | 03:41 PM
guinnessone
Originally Posted by The Saylors
If it is the 2wd with a hcg chassis then you would be able to get one for the 2wd slash hcg and it should work and vice versa if it's a 4wd. Pretty much the worst case scenario is that you have to get a different set of body mounts in order to compensate for the change (ford raptor bodies use these) which is very cheap, around 6 bucks. Just don't get one for a 4wd if you have a 2wd because then it will be a headache.
Pretty sure it is 2wd and the hcg chassis. The chassis is flat across the bottom and then has a support coming down at an angle on each end. The clearance is 3.5 inches.
Edit... Just watched a video converting a slash hcg chassis to lcg chassis and the hcg chassis is the same as mine.
