Toothpick plan doesn't weigh much, is generally the way I go. Drill hole for a snug fit (I do 45 degrees, so the hole catches a little more material on both sides), push the toothpick in and break it off flush, then do the same to the next hole. When done, hit all the holes with thin CA from both sides.
