RCU Forums - View Single Post - Fire Wall Reinforcement for .61 TF P47
Old 06-22-2016 | 12:24 PM
Champstarr's Avatar
Champstarr
Originally Posted by init4fun
This seems to be the #1 problem with ARFs , not enough glue used to properly hold things together . Add that to an engine that vibrates more , and yea , a pulled away firewall isn't out of the question .
When you said you "really slathered the epoxy on" there were two mistakes made . #1 being that any more than can soak into the wood before it cures is just excess weight without all that much increase in strength , and , #2 since epoxy was being used , a bit of fiberglass cloth laid into the epoxy in critical spots would have increased the strength far more than any amount of excess epoxy without cloth would have ....
Thanks for the insight. I ended up using epoxy and eight screws to repair and reinforce the fire wall. If I have future problems I'll use fiberglass cloth that makes much more sense.
