I recently noticed that one of my 2 Fox 45BB engines has some axial play on the crankshaft (the other 45 has no looseness whatsoever). The front to rear movement is approximately 0.7mm, no radial movement at all, however. Is that excessive? Should I replace the bearings? How would I remove the prop drive hub without damaging it, being that it is a stamped sheet metal? thanks.
