RCU Forums - View Single Post - Just a few beginner questions.
Old 06-24-2016 | 10:20 AM
Got RPM's Avatar
Got RPM
A small boat like that will be sensitive to the CG (balance point) and left-to-right trim. Substituting a larger heavier pack may upset the CG degrading performance, and it will allow the boat to run with the left side lower than the right. A pack with too high of a discharge rate (40C or 60C) might damage the motor by supplying too many amps, although the risk is low.
I suggest getting another of the stock packs, then you can bring the boat is, let it cool for a few minutes, then put in the other pack and go run.
