Finally ready for the printer
FINALLY.... Success with the scaling issues I was having with the PDF's. Everything is as it should be now. I've made a few changes to get everything on two sheets. The wing sheet has templates for two sets of root and tips so both the top and bottom of the template guides can be cut and matched.
The fuse sheet has all the templates needed to build the fuse. Some of the wood sizes may need to be adjusted and I'm considering not using foam cores for the top and bottom. Just using a couple of extra stringers and sheeting. We'll see when I get to that point.
With all the above said as with any scaling job not all pieces of wood called out on the plans are appropriate . Use your best judgment and build to suit.
Use these plans as you see fit. If you see something that needs to be changed let me know and I will make the adjustment.
Ken
[ATTACH]2169674[/IMG]
[ATTACH]2169675[/IMG]
