No I means the tip rib would be 2 degree higher The want ever the angle of incident the root rib is. So lets say the root rib angle is 2 degrees and the tip rib angle would be 0 degrees. The change in the dihedral will vary at the trailing edge, the important thing is the relationship of the root and tip ribs!!
