Originally Posted by
sonnytex
Thanks GIZ - ...engine is actually mounted inverted on the plane so in reality it leans out when the ENGINE is upright (the plane being inverted). I will let you all know when I get the carb rebuilt and tested. Thanks
Sonny
FWIW, gas 2 stroke cycle engines don't care if they are upright, inverted, or mounted sideways, because of the pump type carbs. In fact the most common mounting IS inverted. Good luck with your carb rebuild, it is not hard, lots of help here.
