RCU Forums - View Single Post - Tuning Problem
Thread: Tuning Problem
Old 06-26-2016 | 04:37 PM
sonnytex
Actually, I have heard of the vent hole and the effect turbulence causes and considered that possibility. However, since the engine had performed normally in the past I discounted that as my problem. Perhaps I should again consider that possibility. I will rebuild the carb first and see if that helps. If not, your suggestion may be a viable solution. Thanks for bringing that back to mind.
Sonnytex
