The trailing edge will have a greater amount of dihedral but it is not directly related to how many degrees of wash out you have. The degrees of wash out is based upon the difference in angle between the root and tip ribs and the difference in height at the trailing edge is a rotational dimension based upon the length of the tip rib and the point of rotation.
