Originally Posted by
oldvet70
I just finished one and flew it this past weekend. Here's some info:
Center of Gravity 95mm behind the leading edge (very good location, very stable )
Elevator 18 mm on both sides
Rudder 50mm on both sides
Aileron 30mm up, 25mm down
Flaps 30mm down
These are the recommend beginning settings and work quite well. I have English instructions if you have any questions. They are a poor copy but I could try and copy them for you if you like just let me know your email address.
Hi,
I have just been given a jamara 95" pilatus porter and I have found this old threat. It is the same blue/ silver model that is above.
I'd like to power it with a gas engine but I am not sure if the firewall will be strong enough for a gas engine. I have to decide between a dle 20cc ra or a dle 35cc ra.
Any recomendación or advice from someone that had this plane would be appreciated
