Which warbird is this?
1) Designed and built for a particular role. This, of course, doesn't narrow the field much, as most planes are built with a purpose in mind. What makes this one unusual is that most of the planes used in its role were originally meant to be used for something else, and were later used for this purpose. This one was intended for its ultimate use from the start.
2) Twin engine, crew of two.
3) The second crew member was not a pilot, a gunner, a navigator, a radio operator, a radar operator, an observer, a flight engineer, or a bombardier.
4) Less than 25 built.
5) Maximum speed greater than 300mph.
6) Some examples fitted with airbrakes.
7) Two versions produced, each for a different service. Did not enter service with either.
8) Original requirement specifed that this aircraft should use the wing and undercarriage of a mass produced aircraft from another manufacturer. In the end a purpose designed wooden wing was used.
=Adrian=
