Originally Posted by
franklin_m
Then that must mean the FAA is illogical:
"Most manned aircraft operations transit the airspace at or above 500 feet AGL, and an altitude limitation provides a necessary barrier between small unmanned aircraft and a significant majority of manned aircraft operations in the NAS."
- pg 217 / 218 of US Department of Transportation, RIN 2120–AJ60, "Operation and Certification of Small Unmanned Aircraft Systems"
So if everything the FAA does is logical why are we even having this conversation?
So are you also including limiting model rocketry to 400' AGL as well?
