Function List
THRO TRIM
Go to THRO CUT.
First SW SEL and select MIX SW on page 3 and make the 1 black. Press L (List button-second button down on left of TX, to go back)
You should see OFF or ON with the switch flicked, where it says ACT wind that down with the roller to -25%.
Come back to the normal screen and ensure the throttle trim is in the middle, now if you go to monitor to watch what is happening you will see the throttle trim jump from -100 to -125, when you lean the Rx doi the off with the switch thrown, idle with it back (normal position) and use the throttle stick for full power.
With the switch on the turbine will stop, you can set a delay TIME LAG of 1-1.5sec so if you knock the switch you can hit it back and the turbine won't stop
Dave
