RCU Forums - View Single Post - Another Drone Pilot does it Again
Old 06-29-2016 | 08:20 PM
  #3351
Chris P. Bacon
Banned
Originally Posted by Hydro Junkie
I never said PSA or commercials on TV, they are routinely used for bathroom and snack runs. Most watch the local news, for weather and /or sports reports so either lead that segment or put it in between. And, while I do agree that the internet is the cheapest way to go, it's not effective for those that are actually the problem. Those that the FAA can contact already know what's right and wrong so they are not the issue. The issue is those that don't show up on the FAA or AMA lists that fly because they don't think they will get caught. Put out a blanket announcement over the evening news for two or three days and then, if someone gets busted, it's on them and not the FAA..
The news stations don't run FAA announcements free of charger.
I am not a proponent of email announcements due to the use of spam filters. Many times, I see an email get blocked or deleted as garbage, using regular media avoids that
So the FAA should change their entire communications procedures because you don't like it? Perhaps you're using inadequate tools. That really sounds like a personal problem. I get lots of email everyday and don't loose anything. Maybe you should upgrade to a better service provided and/or use better email tools.
The ones that really needed to see it are the ones that probably didn't get it so it's not the AMA or FAA at fault for lack of comunication, rather the failure to use normal media(i.e. over TV and radio station news broadcasts for starters) rather than attempting to use the internet.
