Originally Posted by
Pattern_is_Fun
If the internal resistance is lower, with a higher C rated battery, won't this equate to having more voltage throughout the flight? There would be less battery IR drop giving me more power to the motor - is that correct? Put another way, as the battery IR drop approaches zero won't I get more power at the motor?
Higher C rating equates to more instantaneous power available at any given moment, not total battery capacity. 5000mah is the same whether you use it in 2 minutes or 10.
