Being as you are currently only using approx. 50% of your battery capacity, get the Throttle Tech. You will still see a drop off in voltage even with higher capacity packs without a compensating device like the Throttle tech. While you don't mind the extra weight of a 40-50C pack, seldom does adding weight improve flying characteristics. JMHO.
Gary
