RCU Forums - View Single Post - Frustrated with two DLE 111s
Old 07-02-2016 | 09:57 AM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
I would do a compression check on both cylinders. I doubt a carb issue. The carb is obviously getting fuel into the engine, the dead cylinder is getting wet right? I'm betting the dead cylinder has low compression that prevents it from firing. How close are the serial numbers? Could they have come from the same run?
