Some quick visual mods
Cut the sides down as the vehicle would appear when in action:
Raise the armoured screen:
If you are feeling really adventurous:
M3 Scout Car:
M3A1 troop carrier:
M3 75mm GMC
How to get at the electronics:
First prise out the reloads rack and the radio. They are just glued in place.
This should reveal 2 screws underneath.
Next take out the 2 screws at the rear of the compartment - they are painted so they don't show up in the pic, there is one in each corner tho.
Now you can lift out the turret assembly - be careful as you do this as there is a 8 pin plug connecting the turret to the control board.
The El-Mod board is a drop in replacement, but if you want to use it with the CSI board for battle you'll need to solder on the black connector at the right hand end (or ask the El-Mod guys nicely if they can do it for you).
