Sounds like a case of sloppy building rather than over stressing the airframe. I always use plenty of 30 minute epoxy on the wing joint, the use a 2-3" wide strip of fiberglass all the way around the joint. It won't come apart. If you can take off and land safely and well, you may be ready top move up to another plane, maybe a shoulder wing or low wing plane.
