RCU Forums - View Single Post - how to hover a Magic
Old 10-23-2003 | 02:30 PM
Brains
Default RE: how to hover a Magic
ian firstly you dont need lods n lods of movement to propphang a magic...
if you want to learn prophanging then start off with enough hieght so if you did get into trouble you can get out of it easy...you do use all 4 control surfaces...But you get it right up into a vertical climb and you got t6o keep it there using all 4 of your control surfaces...once you get the hang of it its easy you will be doing it without thinking...
Anyway PRATICE MAKES PERFECT!!!!
Dean
