RCU Forums - View Single Post - cheap back up light trick
Thread
07-11-2016 | 05:57 PM
1
RustedRC
Aug 2014
712
1 Post
Johnstown, pa
Hey guys!
Wanted to share a trick for having back up lights i recently learned. all you do is connect some LED's backwards to your motor wires. i did it in the ascender because it has spots to put LED's in the rear bumper already. works great they come on only when you back up. i used 2 5mm white LED's and 2 180 ohm resistors. you can run the wires down the frame a zip tie or two and good to go and you won't have another plug to deal with when you take off the body.
06:08 PM
. Reason: adding pics
Reply
Like
RustedRC
View Public Profile
Send a private message to RustedRC
Find More Posts by RustedRC
View iTrader Profile
