RCU Forums - View Single Post - gas kadet senior
Old 07-12-2016 | 08:16 AM
egldriver
This photo shows the hatch support rails on each side. The small plywood blocks in the front corners for the hatch screws. Note that I used long maple rails to mount the engine. If you use mounts similar to the stock ones,that is where you would reinforce the firewall from the inside corners described in previous post.
