Originally Posted by
philipat
You should make some accessories for the Panther G that include the early, "chin-less" mantlet, all three exhaust styles (single bent pipe, flame suppressors, oversized curved pipe), both armored covers (cast and welded); and a removable vent/crew heater. Then, we could mix and match. Most of the rest of it are details that can be readily built.
I'd like unpainted tanks. But, I know that you're biggest market is the RTR market and unpainted isn't ready-to-run.
I will mention this
If the Panthers turn out to be very popular (I'm guessing so) then this might be an option. I can already source the exhausts though btw. The single we should be able to modify from the KT if not a direct fit, and the triple exhaust you can pull from a Panther A backplate (as well as the single if you wanted to have a plastic version) as long as you got two plates. That leaves the flame suppressors on the stock G and F. Let me know what you are looking for and I'll see what I can do ok?
