How are you guys balancing this model? Is the CG the 25-28% of total chord like my KMP t-28? I've read 3.5" from leading edge is the sweet spot, which is roughly 25%. Also, are you balancing with gear up or down? I have my KMP balanced at slight nose down, inverted, gear up. When the gear is extended, it is severe nose heavy.
Can I get some insight on this?? Thanks.
