As per my Hangar 9 Hellcat manual : "Make sure the gear is retracted when checking the CG" . . . I see in your photos that you are balancing the plane with the wheels down. I have a newly assembled Hangar 9 Hellcat that I need to balance. Would someone be so kind as to confirm that retracted means that the wheel should be up into the wheel wells of the wings. Thanks
