RCU Forums - View Single Post - Beginner Builder Seeking Advice
Old 07-18-2016 | 05:36 PM
born2build's Avatar
born2build
Hey, Hydro Junkie. How ya doin'? Perhaps you read something in my post that was unintended, even though it was unwritten. I never said you should "beef up" or "over build" an airplane. Light, straight, and strong have always been in the forefront in my building endeavors. I believe you can build strong without any weight penalty by make sure the parts fit accurately and the use the right adhesive for the task at hand. For example, I never use 5-minute epoxy, for anything. Slow-cure epoxy weighs the same but is much stronger. Firewalls, landing gear mounts, wing halves, etcetera all get careful fitting and 30-minute epoxy as I'm sure you'll agree. Stick-built models such as the Sig Kadet Senior or any of the Pat Tritle designs require special attention, of course. Careful sanding and fitting of each part will yield a stronger AND lighter model at the same time. I hope I have clarified myself to your satisfaction. I certainly don't want to mislead a beginning builder into developing bad building habits. Happy landings...Rick.
