RCU Forums - View Single Post - Nexstar select
Thread: Nexstar select
Old 07-20-2016 | 04:57 PM
krokodyl's Avatar
krokodyl
Alright, so I found a problem during assembly. One of the nylon bolts that holds the tail is stripped. I would put epoxy into the bolt or even epoxy down the whole tail, but I don't want to have complications if I brake the tail. I will go to my LHS to see if they have any, but I will most likely have to order them online.
I don't see why they don't at least give you steel bolts, and tell you to use some thread lock.
