RCU Forums - View Single Post - Intruder setup and trimming
Old 07-21-2016 | 07:41 AM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
You will want to run tests to verify your CG location and measure thrust line before adjusting the wing. I usually set up my airplanes with .5 positive incidence on the bench and have no noticeable elevator trim. The reason for this is the a symmetrical wing has to be flown with a positive AOA. If set to zero you will have to fly the fuse at positive as well.
