RCU Forums - View Single Post - Flap setting
Thread: Flap setting
Old 07-21-2016 | 09:31 AM
hsukaria
Originally Posted by krokodyl
Well, the CG is fine, maybe a tad tail heavy. I'm not going to use flaperons, but actual flaps that came with it, but they were locked. Its certianly not the idle, as I had a few deadsticks, and it still came in fast. Im using a 11 by 6 apc prop with an os 46 FX. I also don't think its my approach, because if I try to make it longer i will need to add throttle to prevent it from stalling.
Since I just got the hardware, I think its worth messing with them even if I get good landings without them.
No argument there. The prop is a good fit. You could also try a 12x4 prop to slow the plane down more when landing with engine on.
