Futaba Skysport 4 broke?
Hi, I bought a new Futaba servo on ebay to install into an Airboat. I had enough servos to switch out the receiver on two different boats to use one radio. Well the new S3003 servo didn't have the tab on it to know which direction to plug it in. So I plugged it in an it didn't work so I stitched it around an it worked. I tried again today to test the function in the boat an of course I forgot the right direction to plug it in. Well it didn't work so I switched it again, this time it made the noise when you first turn it on but the radio won't make the servo move. Did I blow up the receiver? Any help or suggestions? Thanks
