RCU Forums - View Single Post - Flap setting
Thread: Flap setting
Old 07-23-2016 | 06:27 AM
krokodyl's Avatar
krokodyl
Ok, so I was reading over the manual, but it does not seem to say anything about having dual aileron and dual flaps. I hooked up the flaps to the flap channel using a y cord. The flap switch operates the flaps, but they for some reason work as ailerons too?!
Also, I have a feeling I will need another y cord. I have a 6 channel rx, and Im not sure if i can get away with only one. Otnerwise one of the ailerons would have to be hooked up to the gear slot, or the flaps would have to be hooked up somwhere else. Anyone know if its possible to do this with only one y cord?
Edit: OK, so I got it to work on the dx8, however when I hook up the dx6i as the buddy box, and presss the button on the dx8, one flap goes full down, and the other one I can control with the dx6i. I should be able to get it figured out after messing around with the settings... My fla+safe in aux, and in gear...
Thanks guys
