Originally Posted by
franklin_m
I would prefer that, with FAA authorized inspectors doing the certifications - whether or not someone is an AMA member.
Section 336 specifically prohibits the FAA from making any new rules pertaining the hobby sUAS operated within the programming of a CBO. So your proposal would in fact be a violation of Section 336 in that it would be a new program imposed by the FAA on hobby RC aircraft. Plus the law itself is very specific.
(3) the aircraft is limited to not more than 55 pounds unless otherwise certified through a design,construction, inspection, flight test, and operational safety program administered by acommunity-based organization;
So unless you can get Congress to re-write this law then there is simply no way for your dream of the FAA imposing regulations on RC modelers to come true.
