Originally Posted by
arjan2856
Hi Guys, i'm considering this model as my first jet. The one thing i don't like so much are the air retracts. I often read that ARF air components are not reliable and needs to be replaced with Robart and Festo stuff for example. I only have experiance with electric retracts so the pneumatics worry me a bit. Has anyone looked into converting to electric retracts? Are the retract mounts all drilled and prepared for the included air gear or would it be easy to fit Electrons or Behotec retracts with the supplied struts? Thanks for the help as this issue is my main concern.
Regards, Arjan.
i understand Electron already made a set to fit the fortune.
retract mounts come pre drilled, but still would be easy to convert.
