Originally Posted by
arjan2856
Thanks for the info Jason,
I'll ask if it's possible to order a Fortune without the mounts pre drilled and without the air retracts. Did you use the full Electron set (retracts, legs and brakes)? and was it an easy install? Thanks!
Regards,
Arjan
Yes the the complete set was fitted. You need to make two simple 4km plates to lower the nose to stop it touching the front structure and you meet to cut out the wheel pocket to clear the wheels. This is not a problem as the wheels sit in these cutouts when retracted. As the electrons obviously have no air nipples to get in the way the units themselves are actually easier to fit then the air ones.
