Originally Posted by
Xenon Paradox
Hello friends, i currently am having an issue with my Kyosho Inferno ST RR's Clutch. at a race last weekend my shoes finally decided they had enough, so i just changed them this morning! as i pulled the old shoes off i noticed the fly wheel nut had backed out abit. so i re- tightened it and installed the new shoes. upon re installing the engine into the car everything seemed okay BUT, when i went to spin my wheels and see if the gearing lined up, i noticed that neither the clutch bell or the drive wheel moved. i proceeded to start the car. and at idle the wheels kept spinning (off the ground) as soon as the wheels hit the ground the engine died... it also dies when i apply the brakes. and when the car is off, it doesnt roll, the wheels stay locked! PLEASE HELP!
(it seems that Neutral doesnt exist anymore)
thanks!
Dan
You've probably tighten the nut up against the clutch bell bearing ,you may need to buy a clutch bell bearing thrust washer kit
which is only acouple bucks.
Those are shims so the clutch nut doesn't tighten up on the bearing!...
