Does the IBU3 light the apple upon reload status? That was always confusing with some of the aftermarket systems regarding if someone took a hit or was "at battery" compared to the tamiya system. I know they are different sequences but in the heat of battle one can confuse the two. Also it gave away the tanks status, If I saw my opponent's apple blink once "reloaded" I'd know I couldn't maneuver freely. Then if still facing the same opponent with these systems I knew after it fired I had till his apple blinked once to gain ground or change vector on it. Yes this is also done with the tamiya system by counting in your head but the visual was more recognizable. Is there the option to have it on/off?
