RCU Forums - View Single Post - Another Drone Pilot does it Again
Old 07-30-2016 | 05:49 AM
  #3571
Sport_Pilot's Avatar
Sport_Pilot
Originally Posted by Hydro Junkie
And I'll bet you're talking a home air compressor, which is a totally different animal since the second stage does nothing more than increase the pressure capability of the pump when the tank gets full. Never seen a turbine compressor, always recip types with either one or two cylinders, the second being smaller in diameter than the first for the increased pressure output. BTW, I used to work at a shop that sold, maintained and repaired compressors so you're not going to fool me with that one. On an added note, there are also tankless constant run compressors that use a pressure switch to operate the inlet and outlet valves. These are almost always used in industrial settings with a dryer unit between the compressor and the load
I am talking about any two stage compressor but especially the jet engines that have a two stage compressor. The fact that it is are is not a positive displacement compressor does not matter in this instance.
BTW large refrigeration engines often have two stage turbine and centrifugal compressors that work much the same as a jet turbine compressor.
