Stock systems in mine...no issues.
JS
Originally Posted by
sillyness
So you guys are still liking this kit, eh? Seriously considering the BVM kit. Is the wiring and are the servos etc holding up ok???
Been scheming... planning a JETI system with a PowerBox Mercury. Anyone running similar? Would you pull the sequencer and use the radio to sequence and the JETI pressure sensor for the tememtry and gear low-pressure Failsafe?
Anything else you'd change or pull out and replace with JETI?
