One thing to remember when setting up an airplane to use for sequence flying in the lower classes is use just enough throw to get you through the sequence. In this particular case reducing your rudder throw down to the point of just being enough will also reduce the pitching. The reality is that except for a stall turn you realistically only need 20-25 degrees of rudder each way to get you through the sequence.
