Ok, on the tap part. To bad you couldn't get that Aquila.
New lesson.
When I build another Riser 100 this winter, and before I glue together the tail end of the body. Insert a CA hinge into it then. Hard as heck to cut through the wood to put it in after body is done and covered. And I didn't use Tite Bond either, I used the white Gorilla glue to build the plane.
2 planes I am getting this winter will be:
1. Riser 100, yea I know. Another one.
2. Durex V Short kit. The Durex V will probably take 4 to 6 Months to build since the Fuse will be scratched built.
http://store.laser-design-services.com/index.php?main_page=product_info&cPath=27&products_id=280.
