RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 08-07-2016 | 07:16 AM
  #2166
Dave Wilshere
Originally Posted by karl hibbs
Dave , That's the answer? do they make stronger springs? Dhc6, I don't use any expo so the ailerons where a little sensitive on the first flight so I reduced them by 15% on my end points and they felt great and still has a good roll rate. the elevator was good .
It works. There are more than one version of the leg, some have a down stop machined in, mine are the originals and the lower section can go over 90 degrees! I just don't do heavy landings and its not been an issue. Airtech do have different wire diameters depends what you have if anything heavier is available. The Ultra Lightning spring might work, think that is 2.1mm wire
Most people fly with expo, depends how your brain is wired. Start with the manual settings and adjust from there
Dave
