Originally Posted by
kmeyers
There are no pics with the new carb. post a couple up. Don't give up!
Do I understand that you have had the same problem with both the original and the replacement carbs? Did you rebuild the replacement carb also before you tried it? Are both carbs incorrectly assembled? Good luck.
