Originally Posted by
spaceworm
Do I understand that you have had the same problem with both the original and the replacement carbs? Did you rebuild the replacement carb also before you tried it? Are both carbs incorrectly assembled? Good luck.
It appears that there are two types of metering kits. One with the machined slot for the lever to clip over and one just a plain pin. The original carb had the latter, so was assembled correctly.
Some good news!
I just got the engine running. I had it running for some 5 or 10 minutes. It is running poorly and required both needles to be almost closed to run at all. I conclude that the metering lever is now bent far too high. My next step is to adjust it down 1 mm then test. More if found to be necessary.
