Originally Posted by
Viper1GJ
Not much progress this week. Homeowner chores and repairs took time priority.
I did get LEF servo wires installed. Made servo plug keeper in wing root from a piece of bicycle tire inner tube punched with hole punch and glued inside the wing root. Keeper stops servo plug from slipping back inside fuse but makes it easy to take it in and out if necessary. Cable clips keep servo wire from getting under the side saddle fuel tank. Servo wire slips inside the cable sleeve and goes to forward fuse to the servo power board.
Very nice!
Our EZ clips are a bit better suited for this job:
We also now have our Ultimate Servo Connectors available in 3 wire configuration for single servo with panel mount tabs to screw the female plug on a vertical surface.
They are 4 times cheaper than the Emcotec ewC solution and fully MIL spec certified against vibrations, heat and corrosion. Certified for 5000 insertion/ extraction cycles and continuous current of 15A per pin.
http://www.ultimate-jets.net/collect...ervo-connector
