Hello All;
Pardon the messy house. But I have the wing on the body and marking the rear area for drilling the holes later on of the bolt pattern.
When I build my second Riser 100 this winter, I starting with the wings first. There is a slight gap in between the trailing edge where the wings come together, I am not happy about it.
But what do you expect, I haven't built anything since 1988. And I think I'm doing pretty good.
And you look real close in the back on the table you see some metallic blue monokote. I am going to use that on my hatch cover and underneath my spoilers. 1 of the spoilers are covered.
This is the Razor plane I had way back when, found it National Balsa web site.
http://www.nationalbalsa.com/Balsa_Razor_plane_p/balsa%20razor.htm
David
