Originally Posted by
sewergod
Has anyone installed bearings in the wheel hub? How about updates to the anti-rotation plate for the electric brake disk? I found that the screws are not quite long enough (only two or three threads) and that there is a space between the back to the anti-rotation plate and the wheel hub, which can cause the brake to drag if one of these three screws come loose. Maiden was completed this past weekend. It flew great!! I noticed these during the post flight gear inspection.
I found the same thing. I replaced the three screws in each wheel with slightly longer screws. One of mine was also loose causing the plate to be slightly warped which was caused the brake on that side to drag. I have not maiden it yet. Hopefully in a couple of weeks. Glad to hear your's flew great. Did you use use the surface throws listed in the manual?
Tim
