starfire struts
Robart struts can be cut shorter. In the instructions they tell you how much, although I have often found that the amount they allow is not enough for most sport jets.
If you take the pin out of the scissor link and remove the spring you will notice that there is a plug in the upper part of the strut that the top of the spring rests on. That plug can be removed fairly easily and it will allow you to cut the struts even shorter than the instructions allow.
The plug is made of nylon and you can simply drill it out with 1/4" drill bit. When you drill it it the bit will usually go most of the way through the nylon plug and then "catch" as it starts to exit the bottom. If you are holding it in your hand the little flanges that the scissor link attach to will rip your hand to shreds (Experience, aint it a *****). To avoid this I usually wrap a towel around the strut and the flanges (sometimes I will clamp it in a vise as well, but you run the risk of bending the strut). Once the bit "catches" the remaining part of the nylon plug will start turning and will come out on the end of the drill bit as you pull it out of the strut.
Now that that thing is out of the way you can cut the upper part of the strut down.
I don't remember what the minimum they can be cut to is, and I am at work so I can't measure one until I get home, but you can easily figure it out by putting it all back together and, with the strut fully extended, insert a dowel into the top of the strut until it hits the top of the spring. Mark the dowel even with the top of the strut and then measure from that mark to the end of the dowel, then you just need to subtract the thickness of the steel plug (included with all robart struts) from this measurement and that is the minimum amount that can be cut off of the top.
When you are done the top of the spring will rest against the steel insert.
Hope this wasn't too confusing.
Kevin Whitlow
