Well yesterday I cleared the Sceptor (almost done too) off of my building bench and now the Riser is ready to be finished. I love to build but feel I suck at covering and really just don't enjoy it so I avoid it. I have to finish the spoiler linkage on the right wing and do some light finish sanding and cover the wings. The vert stabilizer needs to be mounted and both the rudder and elevator needs the hinge points glued in. After that I will finish hooking up the control surfaces, adjust the spoilers, balance it and then the maiden. I wish I would have cowled the motor it takes away from the looks not to mention probably produces drag. I didn't know about the glider drive SK3 motors HK sells when I started this build last June.
