starfire struts
Hi,
If the Robostruts you have are the standard 3/8" straight ones, they can definitely be cut down to fit the Starfire. You will not need to modify the plug or the spring at all. If you'd like, you can send them to me and I can make the appropriate change, or you can give me a call at home and I'll walk you through it.
